harness for deck
Old Oct 22, 2011 | 12:57 PM
sillyboybmxer's Avatar
Default harness for deck
For the rear speakers and such that the s2000 doesn't use, do you guys just tape the spare wires off or.do you connect them all??? I was gonna connect them all because knowing me, I would probably not connect one I would need
Old Oct 22, 2011 | 01:14 PM
S2K.Danny's Avatar
Personally, I used solder/heatshrink for yellow-12v, red-ign/acc 12v, blue-antenna... put the deck's ground under a bolt to the metal frame behind the dash.. and pulled the wires/pins for everything else on the harness. Since I am using the rca pre-outs to an amp for the speakers, nothing else was needed & it made the install/wiring much cleaner..
If there are wires you aren't using, you can just tape em off.. doesn't really matter too much, just whatever is easier for you.
But if you're worried about not connecting it correctly, I would follow the diagrams for the wiring harness & connect everything just to be safe.
Old Oct 26, 2011 | 06:41 AM
BobbyC's Avatar
i connected them all.
i had a second hand head unit my bro gave me with a honda harness already attached.
i didnt really know what wire was what so i just connected all of them.
i may one day add some rear speakers but for the time being, it seems to be fine.
Old Oct 26, 2011 | 06:38 PM
TPhong's Avatar
Just make sure not to let the orange wires from the same harness touch each other, unless you want a disaster on your hands.
s2krazy01
May 5, 2012 08:15 AM
MikeyCB
Apr 8, 2008 09:22 AM
ItsBen
May 1, 2007 02:30 PM
asn
Jun 30, 2005 12:15 PM
Cyberorth
Apr 2, 2002 04:45 PM
