head unit rattling
Old Nov 12, 2011 | 03:35 PM
skyler2k's Avatar
Default head unit rattling
Hey guys so I got a new exhaust and my aftermarket head unit makes an annoying rattling sound when I drive I’ve tried tightening the screws on the back of the removable head unit and the housing. I figured out that is just the removable piece, I took it off and took it for a drive and the sound wasn’t there unless i got lucky for a 10 min drive which never happens. So my question has anyone had this do I need a new head unit or is there a fix i can do? I’ve tried tightening the screws and putting a sticky glue that never hardens and that if anything made it worse. It a kenwood headunit and only a year old.
Thanks Craig
Old Nov 12, 2011 | 06:05 PM
sillyboybmxer's Avatar
Does it have that stupid aluminum sleeve on it?
Old Nov 12, 2011 | 10:03 PM
skyler2k's Avatar
no its more plastic than anything, I just dont want to buy a new one and it do the same thing.
Old Nov 13, 2011 | 08:00 AM
skyler2k's Avatar
Also is there a headunit that they make that doesnt have a detachable face? when mine starts to rattle if i push on it, it stops.
Old Nov 13, 2011 | 10:21 AM
T-Smac's Avatar
I have the same deal. First time it started, I took the HU out to see if I could find anything, but nothing came up. After I put it back in, the rattle was gone. It just came back.
Old Nov 15, 2011 | 05:09 AM
Reckon's Avatar
Downside to a modification like intake and exhaust. The volume of the sound will rattle many things that never rattled with the stock setup. I have an convertible top undertray rattle and a radio door rattle that occurs between certain rpms after I installed my exhaust.
The only thing you can do is remove the entire setup and use some felt or deadening material where you can to make the HU fit more securely. Messing around with it should eventually cure it. Otherwise, crank it up and try not to think about it too much.
Old Nov 15, 2011 | 05:23 AM
TPhong's Avatar
Are you referring to the plastic trim ring that goes around the face of the radio? If it is, make sure 1 of the (usually) 4 prongs aren't broken. The only suggestion I can tell you is to find some really thin weather stripping to put between the radio and the trim ring.
Most single din HU's these days have detachable faceplates for "security reasons", but I believe there are a few radio's that don't.
hook3549
Dec 11, 2010 04:34 AM
Dredd123
May 12, 2010 12:30 AM
ace039
Jul 30, 2001 02:51 AM
