Headunit Install Question
Old Jun 15, 2005 | 07:50 AM
badboypolar's Avatar
Default Headunit Install Question
On the side of tehstock hu is the mounting bracket.
On my new HU there is no place for the mounting bracket. My new HU came with the standard slide backet. How do you mount the slide bracket into the stock area. Just so you know on my car (OEM or not) there is a big open space and there is no area for the slide bracket to "mount" to. It would just be sitting there in open space (on top of the srs ecu).
Is this the way most of you do it or is there a mount kit of some type?
Old Jun 15, 2005 | 08:07 AM
Bass's Avatar
Take the two brackets off your factory head unit - two phillips head screws on each side of the factory radio and screw them onto your new head unit
Old Jun 15, 2005 | 08:09 AM
I can't There are no holes to screw them in at. and I'm not about to make some.
Old Jun 15, 2005 | 08:11 AM
Bass's Avatar
r u sure there are no holes
what type of head unit is it?? did you remove the "standard slide backet" (not needed in the S)
Old Jun 15, 2005 | 08:22 AM
Bass's Avatar
here's a great guide by Lucid
http://lucidauto.com/Merchant2/merchant.mv...y_Code=aftradio
Old Jun 15, 2005 | 09:36 AM
My new HU is a blaupunkt cd-Navi. Yes I have removed the slide bracket. And Yes I am sure it does NOT have the side mounting holes.
Old Jun 15, 2005 | 09:52 AM
Bass's Avatar
ok is there a model number??
checking the blaupunkt site for install instructions - i assume this is still a 1 din sized unit right? (same sizeas the factory head unit)
http://www.blaupunktusa.com/Blaupunk...rt/Manuals.htm
Old Jun 15, 2005 | 10:28 AM
RNS149.
Have the manual. Does not say anything about installation other then wiring and to mount the GPS unit to the outside of the car.
Old Jun 15, 2005 | 10:59 AM
Bass's Avatar
http://www.blaupunkt.ie/download/Installat..._Version(1).pdf
I think you might need a mounting kit
but i'll look some more
Old Jun 15, 2005 | 11:00 AM
Thanks! Bass for your help!
S2020
17
Jun 13, 2016 02:10 PM
JamesD89
Jun 8, 2015 09:52 AM
Kami
May 20, 2014 03:12 AM
dparm
Feb 2, 2009 07:29 PM
mikecl713
Aug 3, 2005 07:13 PM
