HELP - Alpine Dash control problems
Old May 2, 2014 | 09:45 PM
philipMT's Avatar
Default HELP - Alpine Dash control problems
Hi there. I have an aftermarket Alpine unit, installed by the previous owner of my s2k.
The dash controls were working great, but suddenly only the MUTE button works.
Could it be I hit a combo of buttons from the dash controls to deactivate them?
Any ideas how I can fix this please?
Old May 3, 2014 | 05:22 AM
oth's Avatar
oth
In order to use the dash controls with an aftermarket headunit, one needs a dash control interface (DCI).
There are a number of different makers of these, but the basic operation is the same.
From the dash controls there are two wires - one for the mute, and one for all the other functions,
because they operate in the exact opposite manner: the mute provides +12v while the other wire is
a path to ground. In addition depending on the headunit there are two possible implementations of
the mute - either through the same remote command mechanism as the other commands, or through a
hard-wired telephone mute which some headunits support. In some implementations the mute may be
a separate module from the DCI. Older headunits commonly used an infrared (IR) remote and a
separate tel/mute wire, while newer ones usually have a hardwired remote and no separate tel/mute.
Some reasons your DCI may not be functioning:
  • no power to the DCI
  • disconnected dash control wire to DCI
  • disconnected wire from DCI to headunit (if headunit supports hardwired remote)
  • IR emitter out of place or failed (if headunit uses IR remote rather than hardwired)
  • DCI lost its programming
  • DCI failed in some other way
  • bad ground on the dash control itself
  • headunit no longer recognizing remote commands
Unfortunately there is no easy answer, and you're going to need to take things apart and troubleshoot.
Here is a link to DCI technical info from Modifry, a maker of one DCI, which explains general DCI operation well.
Old May 12, 2014 | 03:40 AM
philipMT's Avatar
Many thanks! will check it out this week when i go down to the garage! thanks again
Old Jul 16, 2014 | 12:53 AM
philipMT's Avatar
Solved! I had some loose wires. I re-crimped the wires and all was okay again. Thanks all for the help
jerseyvtec
Nov 3, 2011 04:18 AM
The Loon
Feb 10, 2010 08:41 AM
MurderS2K
Jul 29, 2009 04:51 AM
naruto
Feb 23, 2005 10:40 PM
PAS2KNut
Mar 12, 2004 07:49 AM
