Help Head Unit
Old Jun 13, 2003 | 08:32 PM
mikecl713's Avatar
Default Help Head Unit
The upper left screw wont come off no matter how many times i try.... any ideas?
Old Jun 14, 2003 | 03:10 AM
PAS2KNut's Avatar
I had the same problem. I'll try and explain how I got it out.
This is a two person job. Take the drivers side panel by your right knee off. Then with a long screwdriver have one person from the back put leverage on the bottom of the screw pushing up while the other person from the front tries to remove the screw. The leverage from the back allowed me to remove the screw without having to drill it out. Then use a slightly larger screw thread when you put it back in to eliminate the problem.
Hope this helps.
PAS2KNut
Old Jun 14, 2003 | 04:23 AM
ruexp67's Avatar
Not sure of the problem as it worked fine for me. Is the screw turning, just not coming out? Try a magnetic screwdriver and gently pull the screw free as it turns. It's a tricky technique. If you stripped out the screw try the craftsman 'screw-out.' Pretty handy little deal.
Just some suggestions if you don't have a helper.
black2000
Feb 23, 2010 08:17 PM
hansai00
Jul 20, 2008 10:55 PM
mikecl713
Aug 3, 2005 07:13 PM
1a-race
Mar 19, 2003 02:41 AM
