Removing Head Unit - Help me!?!
Old Mar 18, 2003 | 10:54 AM
1a-race's Avatar
Banned
responded to your post in mid atlantic
Old Mar 18, 2003 | 10:57 AM
Stratocaster's Avatar
I have used a flat blade screwdriver (with duct tape on the blade)and I gently insert it between the dash and the vents. There are two or three clips there. One at each corner, and I think 1 in the center. Try that.
Have your read the Install guide on Lucid's web site?
http://www.lucidautomotive.com/guides/radio/
Old Mar 18, 2003 | 12:02 PM
simmo's Avatar
The top vent does bend down quite far, and you can give it some stick. I should know i had the h/u out 3 time yesterday
145's Avatar
145
Push-up on the part of the dash that is right above the radio door panel (right below the vents) to give you some room to get a screw driver, fingers, etc. in there. That part of the dash is actually quite spongy.
Good luck,
gil
Old Mar 18, 2003 | 12:36 PM
PAS2KNut's Avatar
[QUOTE]Originally posted by dkmillerii
[B]I have followed the FAQ on HU removal, but I'm having a problem.
I pulled gently in the spring-loaded door, and the bottom clips popped fine.
Old Mar 18, 2003 | 04:17 PM
MacGyver's Avatar
Just pull harder. See my webpage...
Old Mar 18, 2003 | 07:18 PM
fmah's Avatar
Someone's guide suggested using a coathanger and making a "J". Poke the short end of the J inside of the trim to exert force from the inside near one of the clips. That worked for me. Otherwise it does feel like the plastic would break first. Kinda like doing a breech delivery and watching the head separate. Ouch!
Old Mar 18, 2003 | 11:42 PM
lucid's Avatar
see www.lucidautomotive.com/guides for a detailed guide on this removal. Use duct tape around the surrounding surfaces to avoid any slips and damage.
Protect your console too! pulling the bottom out is the best approach. You can avoid prying if done correctly. I avoid prying against a soft surface because it can leave an impression in it.
Old Mar 19, 2003 | 02:41 AM
dkmillerii's Avatar
Default Removing Head Unit - Help me!?!
I pulled gently in the spring-loaded door, and the bottom clips popped fine. The problem I having is getting the top off. It looks as though it is stuck between the top of the radio and the "Top Down" vents. I'm worried about breaking it. It said to stick your fingers behind the edges and pull out the top. I can't bend out the bottom far enough to get my fingers behind.
Please help me.
Thanks,
Don
AZS2KDancer
Sep 10, 2012 05:04 AM
ricenoodle56
Aug 27, 2007 10:47 PM
mikecl713
Aug 3, 2005 07:13 PM
Drunken_Monk
Jun 30, 2003 06:15 AM
RossoS2K
Apr 27, 2001 11:28 AM
