Help! Key Fob
you should check out this thread, i've been helping dereklo with a problem in the keyless module you're referring to...he probably knows exactly where its located in the car (i don't) -> https://www.s2ki.com/forums/index.ph...pic=754282&hl=
the keyless module in my s (i suspected that is the keyless module, coz i could remove the green 14-pin connector but everything still working well) is located right behind the start button/dashboard vol control. It's way high up and you could only see it if you slip under the dashboard.
btw, schmittx, do you have a copy of the schem for jap keyless? I still cant get it working. sigh
WhiteS2k
Aug 21, 2003 10:53 PM
