Help me hunt something down...
Old May 15, 2004 | 10:47 AM
  #21
NFRs2000NYC's Avatar
Scratch that.....just cancelled the order....Im gonna order the last thing on the car audio section....
Amp temp, amp current, and volt.
  #22
mikes2k's Avatar
Thanks! I like the brushed aluminum ones They dont seem to hold a peek number though
Sorry for hijacking your thread
Old May 15, 2004 | 10:49 AM
  #23
Yea, I got the aluminums as well.
What do you mean hold peak number??
Old May 15, 2004 | 10:55 AM
  #24
mikes2k's Avatar
The nordskog says it can save max/min levels and recall them later (might be helpful since its going to be trunk mounted)
Old May 15, 2004 | 11:01 AM
  #25
Although neat, I think its useless. I dont think its important what your voltage used to be.....you need to know right now.
Old May 15, 2004 | 11:12 AM
  #26
mikes2k's Avatar
true, I will be flipping the toggle for the second battery long before the max/min info does me any good
Old May 15, 2004 | 11:23 AM
  #27
mcomer's Avatar
One prob - and maybe a battery expert can speak up here - but don't lead-acid batteries have to get pretty depleted before they start to drop voltage? So, can't the battery output voltage still look pretty good (under a small load) but then the battery be unable to deliver enough current to start?
Matt
Old May 15, 2004 | 11:36 AM
  #28
Matt
Good point. So what you are saying that although the volt meter may say 12.5 volts on the gauge, the car might not start because the batt. cannot generate enough current? Very possible.
Also, a bit of sidetracking here....
The s2000 is the first manual car Ive ever owned. Can someone please give me a step by spep on how to start a manual car when the battery dies....(without jumper cables mike )
Something about rolling it, popping into gear...etc....
Thanks.
Old May 15, 2004 | 11:53 AM
  #29
mikes2k's Avatar
[QUOTE]Originally posted by NFRs2000NYC
Old May 15, 2004 | 11:59 AM
  #30
Ok...so.....
Go to an incline....
Put the car into 1st, but with the clutch DOWN. (disengaged)...
Let the car roll to a good momentum,
Pop the clutch, hit the start button???
Correct?
