Help! My Lucid speakers keep cutting off....
Old Jul 16, 2003 | 11:38 AM
Saint_Spinner's Avatar
Default Help! My Lucid speakers keep cutting off....
The previous owner installed some rear Lucid Speakers, an Alpine Amp and Subwoofer in the trunk....sometimes, little bumps in the road would cause these speakers to cut off.....Anyone have any ideas where to start looking for the cause? I don't know whether its a loose wire from the headunit, powersource or what.....
Old Jul 16, 2003 | 01:36 PM
MacGyver's Avatar
Bumps causing cutouts sound like either a loose wire, one wire touching another, or one getting grounded out. 99% says it's a loose wire or one too close to another, so start there.
Old Jul 16, 2003 | 04:58 PM
cool. thanks....Is it possible that it could be any of the wires coming out from the amp? They are all very close to each other and connected to the amp via screws (screwed down)...or would it be somewhere on the speaker system. It seems that the amp AND the lucid speakers cut out, so I'm guessing its probably the power line somewhere....
Old Jul 16, 2003 | 07:00 PM
MacGyver's Avatar
If all speakers connected to the amp cut out, then check the power going to the amp. If it's only two speakers, check the wiring to those two at the amp as they may be touching each other. If the entire system cuts out, suspect power going to the whole shebang.
Old Jul 17, 2003 | 08:55 AM
Sorry, I'm completely new at this...but where do you think I should start looking for the power cut? I'm not sure whether the front speakers are attached to the amp or not, but when things cut out, its the rear lucid speakers and the sub in the trunk...basically everything behind me...the stock speakers and aftermarket tweeters still play on.....
smurf2k
Jan 16, 2008 06:50 PM
Kiwi-S2000
Sep 8, 2007 11:50 AM
cshamash
Apr 1, 2006 11:02 AM
cfcrafting
Mar 11, 2006 03:40 AM
ErikKlenke
Jul 16, 2001 12:01 PM
