Help with sub choice from kicker for lots of bass
Old Feb 15, 2005 | 06:25 AM
S2G-Unit's Avatar
Default Help with sub choice from kicker for lots of bass
I listen to lots of hip hop and rap, with the occasional techno.
Last week I got my Alpine 9835 + CDT CL-61 components.
My amp will be a kicker 600.4. ( i know a kicker rep and get great prices)
I want to fit my sub in the tool well.
Should I go for the 8"L7 @ 450 RMS or the 10"L5. They are both rated @ 450RMS.
The 10" hit's lower frequencies that the 8".
BUT the 8" requires less space.
What would be better for my application?
Old Feb 16, 2005 | 08:48 AM
S2G-Unit's Avatar
any info would be greatly appreciated
Old Feb 16, 2005 | 10:12 AM
NFRs2000NYC's Avatar
They are both garbage. My Alphasonik will toast both of them, sound better, and last more than 3 months. Dont get a kicker.
"Friend dont let friends buy crappy subs."
Old Feb 16, 2005 | 10:54 AM
S2G-Unit's Avatar
lol!!
I`ve always wanted kicker subs. I know a few people that have them and I get a great deals.
ahahah Now put aside that you don`t like kicker...lol
What would sound better?
Will the 10`` have enough space to pump??
Old Feb 16, 2005 | 11:55 AM
MIC's Avatar
MIC
[quote name='NFRs2000NYC' date='Feb 16 2005, 11:12 AM'] They are both garbage.
Old Feb 16, 2005 | 01:05 PM
S2G-Unit's Avatar
So the 8 inch would not sound better even though it requires less space?
Old Feb 16, 2005 | 01:39 PM
japwhiz's Avatar
I put a 8'' L5 in my wifes rsx and I am running it with a old school zr360 amp. I do agree with a some of these guys in saying that the sound quality is not as good as my diamond audio sub in my car. The kicker seems to be more "boomy" (if thats a word )compared to tight clean bass. However, if you are set on kicker, I would think the 8'' would be sufficient and it only requires .33 to .75 ft^3.
I will also say that I do have a kicker amp in my car that I am please with (I do think there are plenty of cleaner amps but, would I hear the difference? probably not). I am running a 650.4 on my diamond Hex components and my 10" diamond sub and my setup hits alot harder and cleaner than my wifes.
just my .02
Old Feb 17, 2005 | 06:11 AM
hukares's Avatar
I have an 8"L7 being slightly overpushed with a 500W amp. It sounds great and has enough power to shake more than just the standard culprits in the S2000. It's true kickers don't sound as good if you play them straight toward yourself. They need to be played somewhere where the sound will reflect or far enough away that you don't hear the cone noise. Definately fine for the kind of music you listen to. If you listened to classical, I would say no.
I've owned a few different kickers over the years along with many others and have never had one fail. The local shop where I get mine pushes his kickers with up to 4 times what they're rated and only occasionally loses them. They can handle enourmous amounts of other abuses too.
-Brian
Old Feb 17, 2005 | 06:31 AM
yes, if your life is hanging by the purchase of a kicker, get the 10"
Old Mar 1, 2005 | 10:55 AM
GroovyNeilNeil's Avatar
Banned
They're dogging Kicker subs like they have extensive experiance...lol. If you get a Solo Baric subwoofer your box has to be built completely different than with a conventional circular subwoofer. If you build it right...it'll sound better and hit harder than their little whatevers...
If I were you I would get the 8" L7 and have your Kicker dealer build you a big box to spec. You won't regret it. Any particular reason you're going with a 600.4?
