HELP Turn signal
Old Jul 15, 2011 | 08:45 PM
00S2Ked's Avatar
Default HELP Turn signal
my passenger side turn signal is not working for some odd reason, But works when i turn on the emergency light. I checked the bulb its seems to look fine.. Fuse looks good. checked wiring.. all looks good. Cant seem to figure out what could cause this problem.. any helps guys/girls ?
Old Jul 16, 2011 | 01:31 PM
lithoman's Avatar
swop bulb with the drivers side.. might be a bulb that has double filament.
Old Jul 16, 2011 | 07:09 PM
00S2Ked's Avatar
already done that ... still nothing
Old Jul 26, 2011 | 07:01 PM
00S2Ked's Avatar
anything ???
Old Jul 28, 2011 | 05:59 PM
LagunaBlu2k's Avatar
TTonight while driving up highway both turn signals suddenly quit working emergency lights work and side markers work but when I flip signal stick it doesn't work green arrows don't even come up on dash like the actually stick stopped working but I can still turn on headlights and high beams with same stick WTF?
Old Aug 10, 2011 | 01:09 PM
Krenath's Avatar
I haven't had this problem with my S2000 but on an old '75 Toyota I used to have, I once had *exactly* this problem, down to the fact that hazard lights worked but turn signals did not.
On the Toyota, the problem turned out to be corrosion on a ground wire for the tail lights. When I cleaned off all the corrosion, put on some dielectric grease, and bolted it back together, everything worked fine.
This may not be your problem, but it might give you something to look for.
scottdh20
Mar 24, 2019 07:08 PM
plizzat
Aug 4, 2014 06:45 AM
motoinfantry
Aug 17, 2009 01:02 PM
PLYRS 3
Jun 25, 2006 07:46 PM
bobatimez
Nov 4, 2001 09:37 AM
