HELP: USDM KEYLESS CONTROL UNIT ISSUE
Old May 29, 2013 | 01:26 AM
disonesaplaya's Avatar
Default HELP: USDM KEYLESS CONTROL UNIT ISSUE
DOES ANYONE KNOW HOW TO WIRE UP DOOR LOCK AND UNLOCK TO THE KEYLESS CONTROL UNIT DIRECTLY FROM THE PCB FOR A USDM S2000. PICS?? IVE SEEM ETANG THREAD BUT ITS FOR A JDM S2000. IVE SEARCH AND HEARD PEOPLE TALKING ABOUT WIRING THE DIRECTLY TO THE PCB BUT NO PICS OR DETAIL. THANKS IN ADVANCE.
Old May 29, 2013 | 10:31 AM
BLAQ&GREYs2k's Avatar
Thats what i am working out myself right now. You have the option to take the cover off of the keyless module and solder the lock and unlock wires of your alarm system directly to the keyless module circuit board. OR you can use the DEI 451M module in line with the factory lock unlock wires going to the keyless module. I have yet to do it because if you do it incorrectly, you WILL fry the keyless module. Im pretty sure you have to cut the wires to install the 451M, I just havnt gotten the courage to cut up the electronics on a nice S.
Old May 29, 2013 | 11:42 AM
yea i want to solder it directly to the pcb but the only pics i can find is etang jdm s2000 ones. i need to know where the points are located on the usdm one. i dont wanna run the extra relay if not needed.
Old May 29, 2013 | 12:44 PM
S2kAndTheAnt's Avatar
https://www.s2ki.com/s2000/topic/832...unit-diagrams/
Old May 29, 2013 | 04:41 PM
Read the second post
https://www.s2ki.com/s2000/topic/325...rm-door-locks/
Ive been told do to it this way but dont understand. Is there two empty pin slots on the keyless connector that just happen to be lock and unlock? Ill have to crawl under the dash and check but doesnt seem logical at the moment.
Old May 29, 2013 | 04:52 PM
Just went and took a look. Looks like it might work . The connector has two empty slots for a female pin. Unplugged the connector, there are two male pins there. Ive found 2 different sources saying it works. I'll try tomorrow after work and report back.
Old May 29, 2013 | 08:46 PM
i wanted to solder directly on to the pcb like this
https://www.s2ki.com/s2000/uploads/m...3610_thumb.jpg
for example but this is for an jdm s2000 i need to know the point for the usdm one. not the pins.
Old May 30, 2013 | 11:04 AM
Why would you take the module apart and solder to the board when you can make it look factory with inserting pins into the connector. You are adding more work for yourself with a lesser quality finish?
Old May 30, 2013 | 01:01 PM
its acutally alot easier then running relays and extra wires. where i just solder the unlock and lock wires. i cant seem to get it working correctly with a relay. let me know if u figuire something out.
Old May 31, 2013 | 06:17 AM
Maybe you misunderstood what I was saying. NO relays needed. You can just crimp on a pin to the green and blue viper alarms wires for lock un lock, and stick them in the two open slots on the connector to the Keyless Module. Done. Factory finish. Why would you want to take it apart and solder on the board? This is an S2000 I try to keep it as clean as possible when screwing with shit
