HELP: USDM KEYLESS CONTROL UNIT ISSUE
Old May 31, 2013 | 04:47 PM
BLAQ&GREYs2k's Avatar
Just hooked everything up and the Viper alarm now works WITHOUT having to solder the green and blue wires to the board. Like I said, un plug the connector and fish your green and blue wires through the two open spots so they will make contact with the pins when you plug it back in. Green wire next to the red/white wire on the connector, blue next to the black wire. DONE. WORKS. BOO YAAA such a good feeling.
Old May 31, 2013 | 07:52 PM
disonesaplaya's Avatar
sweet ill try that this weekend thanks..
Old Jul 9, 2013 | 10:30 PM
skibbz's Avatar
That looks to be correct, based on the USDM wiring diagram that schmittx uploaded.
https://www.s2ki.com/s2000/topic/832...unit-diagrams/
I'm going to go try it out...
Old Jul 9, 2013 | 11:44 PM
skibbz's Avatar
https://www.s2ki.com/...-unit-diagrams/
Yup, I can confirm that this is correct and makes wiring up door lock / unlock very simple and clean.
Does anyone know the part number for the OEM wire pins? I'd like to add those for a nicer install down the road...
Old Jul 10, 2013 | 11:50 AM
Originally Posted by skibbz' timestamp='1373437813' post='22657225
[quote name='BLAQ&GREYs2k' timestamp='1370047625' post='22579523']
[/quote]
I wondered the same. Its not a standard pin size because I tried using the wire/pin from my DEI/Viper alarm and it would not go into the connector.
etang789
Dec 30, 2010 06:59 PM
jonneson
Apr 27, 2010 01:16 PM
pininfarina456
Jan 16, 2008 09:02 PM
viper7169
Apr 26, 2006 06:46 PM
CIVICTOS2000
Aug 22, 2005 10:16 AM
