Hid
Old Mar 14, 2012 | 07:53 PM
S2kmonkey's Avatar
Default Hid
So my Hids wento out both of them one turns on once in a while so that's the ballast can I just replace it do I have to take off the fender to do that?.. Some1 told me that I'm going to have to change the whole headlight
Old Mar 15, 2012 | 07:18 AM
TPhong's Avatar
If you need to replace a ballast, then you'll need to take off the front bumper in order to remove the headlight. The ballast is mounted underneath the headlight housing. You "might" be able to get to it by pulling the fender liner back, but the headlight bracket underneath, might pose a problem.
Old Mar 29, 2012 | 07:02 PM
S2kmonkey's Avatar
i took it off already barley doing it i was able to get it off by taking off the bumper so one ballast is out the other was just the bulb how do i replace the ballast?
Old Mar 29, 2012 | 08:47 PM
NFRs2000NYC's Avatar
I think you need to remove the headlight as well in order to unplug and unbolt the OEM ballast. As far as replacing, you can get an OEM ballast or get an aftermarket one and put it in the stock location. Aftermarket ballasts are MUCH smaller, so you will have to figure out a way to mount them, but it should be a non issue.
hellspare
May 10, 2011 04:30 PM
hellspare
May 5, 2011 10:53 PM
thewiseboatmaker
Apr 14, 2010 02:56 AM
Valentino007
Jul 26, 2007 08:02 PM
immaViLLaiN
Dec 28, 2006 09:06 AM
