High Beams stuck on
Old Aug 28, 2011 | 05:24 PM
DISCONTD's Avatar
Default High Beams stuck on
My high beams are stuck on, this has never happened before, I put them on a country road then all of a sudden they wouldnt come off. has anyone else had this problem? could it be wiring problem? or a bad switch?
Old Aug 29, 2011 | 05:20 AM
TPhong's Avatar
It' could be a bad switch or possibly the high beam relay is stuck open.
Old Aug 29, 2011 | 12:21 PM
T-Smac's Avatar
Is the hi beam dash light on? Are both hi beams stuck on? If both are, then its probably the switch (should have dash light then). If its the Left hi beam only, its probably Headlight relay 2 (or very unlikely the switch and fuse 43 (20a) is burnt up). If its the right hi beam only, it looks like Headlight relay 1 could be bad.
Old Aug 30, 2011 | 05:21 AM
DISCONTD's Avatar
turns out it was the switch. easy fix, alot better than some electrical problem. thanks everyone for the help
Old Jul 6, 2019 | 07:58 AM
AP1Chief's Avatar
Sorry to bring this back from the past, but this just happened to me last night... What switch are we talking about?
talking about the combination light switch that controls the turn signals and low/high beams?
aznsupastar
Sep 6, 2016 07:01 PM
Waggylau
May 13, 2013 10:12 AM
thebigcheese
Feb 2, 2009 10:54 AM
learnerspermit
Sep 1, 2005 08:23 AM
