HID problem
Old May 12, 2013 | 02:42 PM
Waggylau's Avatar
Default HID problem
Hi,
Hope someone can help...
After 2 new bulbs and ballast was put into passenger side headlight assembly everything worked fine.
Then next day i turn high beam on and the low beam(passenger) switches off and won't come back on. Everything else is fine. 10 minutes later I just turn low beam on and both work. They both work later until I turn high beam on and yet again passenger Low beam turns off.
Could it be bad connections??
Thxs
Old May 13, 2013 | 09:32 AM
AP1Drew's Avatar
Maybe the relay isn't switching back... you can try swapping the headlight relays left to right and see if the problem switches to the driver's side.
Old May 13, 2013 | 10:12 AM
Waggylau's Avatar
Thxs, tried that also and checked fuses... But at the moment no passenger low beam.
K.Shift
Feb 22, 2018 11:34 AM
RedhotS2k5188
Jul 23, 2009 06:34 PM
s2kev
May 21, 2006 01:22 PM
learnerspermit
Sep 1, 2005 08:23 AM
anthonys2k
Jan 25, 2005 06:52 PM
