How Do I access the AUX on my 02 HU?
Old Jul 10, 2003 | 04:10 PM
nownor's Avatar
Default How Do I access the AUX on my 02 HU?
I did a search, but I didn't come up with anything definitive. I'm getting the PIE Honda AUX converter that supposedly converts the OEM CD Changer connection on the back of the OEM unit into RCAs. My question is, how do I put my 02 unit into the AUX mode when I get it? This may be a stupid, question I understand, but I'm just not sure if it automatically detects something there and when I cycle throught all the modes (AM, FM, CD..) that AUX will appear, or do I have to do something else? Thanks for all your help!
Old Jul 10, 2003 | 09:05 PM
LATEOTT's Avatar
I don't know for a fact but it would make sense that you would just select the CD changer on the HU. I mean, if the converter basically intercepts/uses the CD changer inputs...
Old Jul 10, 2003 | 10:27 PM
rworne's Avatar
When the PIE is not connected, you get AM/FM and CD when the PIE adapter is connected, the CD button becomes CD/CD-Changer.
That's how mine works anyway. Just make sure you ground it to the radio or it wines like a mofo.
Old Jul 11, 2003 | 02:52 PM
nownor's Avatar
got instructions on how to ground it?
Old Jul 12, 2003 | 04:09 PM
rworne's Avatar
Try this thread:
https://www.s2ki.com/forums/showthread.php?...?threadid=89615
Basically, where you plug in the RCA's there's an exposed metal shield, solder a wire onto this shield and attach the other end to one of the bolts on the radio. It cuts down considerably on the ground-loop hum and electronic noise.
If the iPod or whatever is not attached, you'll hear interesting noises over the speakers when the AUX is selected. The Radio/CD and all work just fine though as well as AUX when you have a device hooked up to it.
Old Jul 14, 2003 | 07:23 AM
Luft46's Avatar
I just used an alligator clip, clipped it onto one of the outer RCA plug metal parts and attached the other end to a radio screw.
It works perfect, and I have been using it like this for about 6 months now with no problems....
goofy
Feb 13, 2011 07:35 PM
street_ruler
Jun 6, 2010 08:03 PM
Somehondaguy
Sep 25, 2006 02:28 PM
skwerl
Jan 14, 2006 10:41 AM
guybutler
Jun 18, 2002 01:12 PM
