How do you remove the radio door?
Old Jul 2, 2005 | 02:27 PM
Sparta's Avatar
Default How do you remove the radio door?
I have the center vent assembly, including the original radio door already out. I see there are two tine pins that hold the door in place where it hinges. I guess I need to remove those pins to undo the door, but how does one do that? The only thing that will fit inside those holes containing the pins is a paper clip, but I can't catch the pins with enough leverage to slide them out... they seem fixed.
Old Jul 2, 2005 | 06:21 PM
xenosis's Avatar
well you would have to push it out. ive heard people saying they used clothes hangers, some used pins they had, my friend used one of those little air pins from a old football. i on the other hand just used a really really small screwdriver + some WD-40. and pushed it out.
Old Jul 2, 2005 | 06:44 PM
mcola's Avatar
I have found that an allen wrench works very well. Find one that barely fits in the hole and then push the pin out far enough to get some pliers on it. Use the pliers to pull the pin out the rest of the way.
Old Jul 2, 2005 | 08:02 PM
steven975's Avatar
be sure to be on the lookout for a round spring that will come out. you need that to make sure the new door opens. it can be a little challenging to set the spring; you have to tension it with a finger while putting the new door in. don't put in the pins until you have the spring right.
Old Jul 2, 2005 | 09:35 PM
xviper's Avatar
Here is a thread on this. It's listed in the "FAQs" in Technical (UTH):
https://www.s2ki.com/forums/index.php?showtopic=251894
Old Jul 3, 2005 | 07:28 AM
PdC's Avatar
PdC
Here is another link:
http://lucidauto.com/Merchant2/merchant.mv...ode=radioremove
Old Jul 4, 2005 | 01:25 AM
YuriArts's Avatar
Where did you get the new radio lid from? Is there an internet shop that sells them? I can't find them anywhere in Europe besides the dealer (they ask >$100).
Thanks.
Old Jul 4, 2005 | 06:44 AM
xviper's Avatar
Thanks.
http://hardtopguy.com/store/customer/produ...1&cat=26&page=1
JS2k.com
Mar 14, 2011 05:48 AM
tattedups2k
Dec 16, 2008 09:28 PM
aznprydefloz
Jun 18, 2005 01:39 PM
