Initial set up - matching amp to speakers
Old Sep 6, 2015 | 12:30 AM
Valkyrie's Avatar
Default Initial set up - matching amp to speakers
So I've just bought some JBL MS62C's for the fronts, albeit secondhand I decided on these over the Focal PS130s in the end and am hopefully going for a Genesis Profile 4 to power them and the slimline sub in the spare wheel slot (JBL MS-10SD2). Objective is midbass and I've treated the doors with 2mm silent coat and 5mm CCF like so;
However I was wondering if this particular Genesis class A/B amp would provide enough power as its only rated at 55w per channel and the comps spec 80wrms and the sub at 250wrms (all at 4ohms). Will this be enough bang from the amp or should I look for something like say a JBL GTO 1004 or Audison SRX3 which is 100w per channel?
Also, after inspecting my inline fuse in my 4awg wiring kit there appears to be water damage so I'll need to replace it. What size fuse would be best for this set up? Was thinking around 100amp but am unsure
Cheers!
EDIT. The Genesis amp seller fell through so I've picked up an Audison SRX3 which hopefully will be ideal, thoughts and experience welcome of course.
Old Sep 6, 2015 | 07:16 AM
oth's Avatar
oth
100 amp fuse is probably fine for 4ga wires, but from the SRX3 manual it looks like the amp itself
has a 30 amp fuse, so in the interest of added safety I'd go with a fuse closer to 30 amps - 50?
Old Sep 14, 2015 | 12:14 PM
PorgyS2K06's Avatar
I always aim for more headroom. You can adjust for too much power, you can't for too little.
CreAziaN
Jun 25, 2010 10:34 AM
JP_BLACK
Feb 11, 2005 05:19 PM
S2G-Unit
Feb 8, 2005 06:09 PM
h0ckeypunk
Jan 14, 2004 04:45 PM
vodalus
Feb 13, 2003 08:07 PM
