Installed rear speakers
Old Jul 8, 2011 | 01:51 PM
  #31
HS2K007's Avatar
I ordered a metra harness for the pins. They sell both the male and female sides. You need the male connector, best described as the one that plugs into the factory radio. I looked at a write on here to see which location they went into. You will need a pin removal tool to get the new pins out of the harness, or you will need to be really good with a sharp pick.
Yes, still running factory fronts, or at least what was in the car when I purchased it. They are blue and seem to be a mylar cone and not paper. Any how, they look better than most factory speakers and with my new rears, they sound ok. I did add a sub for a little more bottom end, so the fronts and rears are only for mid and highs. I have custom mounted a bass knob on the center console so I can adjust my bass as needed. It works for me.
Old Jul 11, 2011 | 12:55 AM
  #32
rumberobueno's Avatar
I ended up hacking the harness from my Civic's cassette deck since it was gathering dust anyway.
I managed to take out four pins with the help of a small screwdriver.
When I installed them into the HU harness I managed to swap the right rear with the left rear speaker so I had to take them out and redo. I guess I am getting good at it ;-) ....
The sound is definitely much improved over the stock setup.
I also added an auxiliary input and routed the cable to the box that's in between the seats. It sounds even better when I connect my mp3 player to the HU.
Thanks for the writeup and the guidance.
Below are the HU harness connection for future reference.
As you look at the back of the radio with the harness facing to you the top pins are numbered 1 to 10 left to right and the bottom ones are 11 to 20 also left to right.
Code:
Pin 	 Function 	                     Color 	 Pin 	 Function 	          Color
 1 	 Antenna/Remote Amp Relay 	 Yellow/Green 	 11 	 N.C. 	                    -
 2 	 12V Accessory Power 	         White/Red       12 	 N.C. 	                    -
 3 	 Dash Remote 	                 Green/Red    	 13 	 N.C. 	                    -
 4 	 N.C. 	                              -          14 	 Mute 	                Yellow/Blue
 5 	 Right Rear Speaker + 	              -          15 	 Right Rear Speaker - 	    -
 6 	 Left Rear Speaker + 	              -          16 	 Left Rear Speaker - 	    -
 7 	 Right Front Speaker + 	         Green/Black 	 17 	 Right Front Speaker - 	Light Green
 8 	 Left Front Speaker + 	         Green/Yellow 	 18 	 Left Front Speaker - 	Gray/Red
 9 	 Illumination Signal 	         Red/Black 	 19 	 N.C. 	                    -
 10 	 12V Memory Backup Power 	 White/Blue 	 20 	 Ground (chassis) 	Black
Old Apr 1, 2012 | 01:14 AM
  #33
T-Smac's Avatar
The vents are also used for closing the door. Rather than pressurizing the cabin as you slam the door shut, the pressure is vented through those vents, through the trunk and out the grille hidden behind the bumper.
Old Apr 1, 2012 | 05:19 PM
  #34
grkboy707's Avatar
Very clean install. I recently put some 4x6s in mine, right on top of the panels. I was really sloppy, but I was antsy to get them done. They do sound very nice though
Old Apr 2, 2012 | 05:55 PM
  #35
TwisS2000's Avatar
Came out great, are you using the stock head unit? Do you notice the mids much or is this providing a treble boost?
Old Apr 2, 2012 | 09:31 PM
  #36
I originally did this mod and added two 4x6 rear speakers.
They sounded good but were distorting at higher volume levels so I decided to install 6.5" speakers instead.
With the 4x6 speakers you could hear both mids and treble.
The 6.5" are much better at higher volume levels (read: with top down ;-)) and provide better low end which the 4x6 were lacking.
I am using the stock head unit.
One strange fact is that even though my front and rear speakers are the same (Polk DB 651) the head unit doesn't seem to route too much base to the rear speakers.
An aftermarket unit might fix that but the OEM sounds really good the way it is (I am using an AUX input + mp3 player) to warrant installing an aftermarket unit.
Old May 19, 2012 | 09:42 AM
  #37
DaGou's Avatar
when you talked about adding pins and the metra connector thing...are those slots used in and AP2 for the crappy hoop speakers? Would kill the hoops to put in those rear mounted speakers???
Old May 22, 2012 | 05:52 AM
  #38
S2Keri's Avatar
VERY nice install
Old Jun 5, 2012 | 04:49 AM
  #39
garyz's Avatar
Originally Posted by HS2K007
I bent the metal by taping it up so I would not scratch it and using a dead blow hammer. The wires behind the radio have been documented on this site and I did not take pics, as I did it last year. The radio has the option for rear speakers, it just does not have pins in the connector. You can purchase the pins, our a metra harness that has the honda connector. Search on the site for the radio pin out diagram and label the wire and run down the side of the center console or under it. It worked out great. If someone already has the links and posts them here, you will have everything you need to do this.
I would love to find the post that explains the " ...wires behind the radio." I have taken the radio out, and see a lot of empty male pins on the back of the radio, but no way to determine which ones would power a pair of rear speakers!
Old Jun 5, 2012 | 05:24 PM
  #40
oth's Avatar
oth
If you look at the post a few above yours in this same thread, you'll see a chart of the wire/pin positions
and their functions.
This post may also be useful.
