Installing SWI-JACK for radio
Old Apr 13, 2010 | 10:02 AM
blink962's Avatar
Default Installing SWI-JACK for radio
hi
i have a alpine radio and a swi-jack modul for radio button above steering wheell..
i would like to know how i instal it..
whick wire i need to hook up? i wired the red and black...
which other wire i need to hook and to where?
installation is there..
http://www.pac-audio.com/PACProductData/SW...ions_061407.pdf
thanks
Old Apr 13, 2010 | 10:45 AM
Juice Steez's Avatar
I would assume that it would be the dash switch wire (green/red) on the OEM harness. Lets see if anyone else can chime in on this.
Old Apr 14, 2010 | 05:26 AM
takeshi's Avatar
Good luck with it. As always, I'd highly recommend the Modifry DCI -- especially if you're using an Alpine head unit as he sells a PnP harness. Install takes a matter of seconds.
Old Apr 16, 2010 | 11:48 PM
blink962's Avatar
come on please help me guys
Old Apr 18, 2010 | 06:17 AM
blink962's Avatar
i need to know what is the SWC wire?
thanks
Old Apr 18, 2010 | 08:54 AM
blink962's Avatar
which is the SWC wire on the harness of the car?
thanks
Old Apr 19, 2010 | 10:24 AM
blink962's Avatar
im the only one having a pac swi-jack modul!?
Old Apr 19, 2010 | 02:38 PM
NFRs2000NYC's Avatar
Yes. I wish you came on and asked about the steering wheel controls before you made your purchase. We all have a Modifry DCi, a product specifically made for the s2000.
Old Apr 20, 2010 | 01:37 PM
Krenath's Avatar
The PDF file that you mentioned links to another PDF file that claims to describe how to get the module to work with the S2000.
http://www.pac-audio.com/swixprogramming/s...Vehicles&ID=322
Connect the SWI-X 's White wire to Pin # 3 (Green/Red) of the above connector.
Using the mute button to control aftermarket radios with a mute input:
  • Using a 12v SPDT relay, connect pin 85 to Honda's pin #14.
  • Connect pins 86 and 87 to ground.
  • Connect pin 30 to the phone mute input wire of the new head unit.
  • If there is a wire (normally brown) in Pin 11 it will need to go to chassis ground.
Seriously, the Modifry harness is FAR less difficult than this.
I connected the Modifry harness to my head unit harness by matching colors on all the wires. Then I plugged the DCI into the extra connector on the DCI harness. Then I turned the car and radio on and it was done. (well, actually, I also hooked up the speed-controlled-volume wire, but that's optional).
Raziel1
Feb 20, 2012 03:11 PM
norbs2k
Jan 11, 2011 02:19 PM
hellspare
Oct 21, 2008 12:15 PM
NFRs2000NYC
Jul 31, 2003 05:09 AM
Andy Kirk
Apr 26, 2003 09:58 PM
