Installing system need help ASAP
Old May 6, 2007 | 01:23 PM
Rob_s2k's Avatar
Default Installing system need help ASAP
Hey guys I am in the middle of my system install and need some help. My HU is an Alpine 9861. It has a wire coming out of it that is labeled "Remote".
1. Do I just tap my remote wires for the amps into that or do I need to tap somewhere on the wiring harness?
2. I have two amps. Can both remote wires for the amps be tapped into that one wire coming out of the HU?
3. Can I run one power wire from the battery to the trunk and then split it for two amps? Or do I need a separate power cable for each amp?
Any help is appreciated.
BTW how the heck am I going to fit all the wires in back of the HU into the dash. The space was cramped before and now with my rca cable I dont know how I am going to do it. Any tricks?
Old May 6, 2007 | 01:43 PM
NFRs2000NYC's Avatar
Yes to all your questions.
Old May 6, 2007 | 01:50 PM
Rob_s2k's Avatar
Thanks appreciate the help.
Old May 6, 2007 | 03:31 PM
VTECorona's Avatar
If you are running anything high power (400+ combined RMS watts) then I would go with 4 gauge, if the amps are relatively small then you should be cool with 8.
This page has a chart of recommended power wires based on RMS wattage and distance. Since you are powering 2 amps off of 1 power wire you should consider using 4 gauge.
http://www.the12volt.com/info/recwirsz.asp
BerlinaBayRidah
Aug 1, 2008 11:46 AM
sckscrkeeper
Sep 22, 2006 05:02 PM
mr_grand_prix
Dec 15, 2005 08:29 PM
tomthumm
Feb 6, 2005 10:44 AM
KLN
Dec 31, 2004 12:48 PM
