intsalling aftermarket alarm, but having problem
Old Jun 7, 2007 | 04:15 PM
J.nguyen's Avatar
Default intsalling aftermarket alarm, but having problem
my 2000 AP1 that came standard with no Factory alarm, just the keyless entry with keychain remote, doors lock and unlock perfectly until right now when i am installing aftermarket alarm (Viper 5002) and the DRIVER side door isnt locking or unlocking (i do hear a noise) but passenger side door is locking and unlocking working perfectly.
what can be the problem?
Old Jun 8, 2007 | 08:39 AM
vspc2nr's Avatar
wait, you hear a noise but it dosen't lock?? Is the door closed when you do this, cause it will not lock when the doors open. last is take into consideration that the door locks are 7yrs old. maybe its time to buy a new one
Old Jun 8, 2007 | 10:21 AM
J.nguyen's Avatar
yes door is closed, but how come it locked when i had oem keyless entry? well i guess i can give it a try and replace it, the DOOR actuator needs to be replaced?
Old Jun 8, 2007 | 10:27 AM
vspc2nr's Avatar
try this, with your finger, press the lock lever(not switch) but do not push it. Try to help it lock without putting too much pressure to lock it with your finger. If it locks then you have a bad/weak door lock accuator. If it twitches, you have a bad accuator. replace as nesessary.
Old Jun 8, 2007 | 11:00 AM
J.nguyen's Avatar
will try, thanks for the advice,ill keep it posted
tjhmortimer
Jan 22, 2014 12:57 AM
jammer2209
Oct 11, 2010 10:23 AM
silver696
Dec 15, 2009 01:32 AM
chris_nl
Jun 1, 2009 05:09 PM
Bassoctopus
Jan 1, 2006 08:18 AM
