ipod connector problem
Old Nov 20, 2005 | 09:44 PM
JPNSPEC's Avatar
Default ipod connector problem
I recently installed a DFK technology ipod connector. Everything worked perfectly fine the day I installed it. LAter on, I tried to plug the ipod back in the connector after the engine was running, and all of a sudden, it didnt play. Did I shorten something?? I tried everything from turning off the engine then re-starting it to even taking out the negative battery and reseting the stereo. My radio and CD player works just fine but the ipod does not play. I have a feeling I tweaked the connctor somehow..any info would be greatly appreciated, thanks!
Makoto
Old Nov 22, 2005 | 10:55 PM
JPNSPEC's Avatar
anyone??
Old Nov 23, 2005 | 07:06 AM
scareyourpassenger's Avatar
A couple scenarios.
The ipod has a special mode for the adpater and it needs a reset to work
(doubtful) On the click wheel ipod hold menu and select till you see an Apple logo.
The adapter has crashed. Un plug your negative terminal of the battery or pull the radio fuse.
The headuntis in the S2000 can be very picky about how they are used with an ipod. I know, I went through 3 adapters before I got one thta worked.
J
Old Nov 23, 2005 | 04:14 PM
JPNSPEC's Avatar
what kind of adapter did you end up with? I tried disconnecting the negative battery but still did not work. maybe i should try the fuse...thanks for your input. did anyone else have a similar problem??
Old Nov 28, 2005 | 11:32 AM
JPNSPEC's Avatar
bump
Ap2batman
Dec 11, 2010 10:46 PM
aresk3b
Apr 14, 2010 11:45 AM
burak
Oct 8, 2006 11:50 AM
inactiveuser1114
Jul 23, 2006 04:28 PM
Honda 367
May 13, 2005 03:59 PM
