key fob range
Old Jan 14, 2019 | 11:05 AM
ragtophardtop's Avatar
Default key fob range
How much range do you have with your stock S2000 key fob? Mine is pretty limited, about 15 feet, which is a lot less than I got in my miata of similar vintage. I replaced the battery in my fob, so I know it's fresh. I'm thinking the alarm that was dealer installed may be the reason for the limited range, but I'm curious know others' key fob range.
Old Jan 14, 2019 | 11:33 AM
Fokker's Avatar
S2000 key fob range has always been short as far as I know. I've never had any variance across the 3 that I've owned.
Old Jan 14, 2019 | 12:44 PM
engifineer's Avatar
Yep, short. About 20 - 30 feet tops, maybe 50ish if I put it to my head. And yes... that does actually work :P But I normally do not care all that much since all it does is unlock and lock.
Old Jan 15, 2019 | 06:55 AM
engifineer's Avatar
Originally Posted by isthisusernameavailable
Yes. Or hold fob under chin when you press. Maybe doubles the range.
Correct, that is where I held it when I tested that. Under the chin. Worked pretty well... slightly less well for my wife ... she says because I have more water in my head lol
Old Jan 15, 2019 | 07:17 AM
Or maybe less air?
Old Jan 15, 2019 | 08:04 AM
engifineer's Avatar
Originally Posted by ragtophardtop
Or maybe less air?
I like that reason better! lol
Old Jan 15, 2019 | 08:34 AM
oth's Avatar
oth
In a car with an alarm, the key fob communicates with the alarm control unit rather than the
keyless entry unit - if it's hidden in a more electrically shielded area (likely), it will shorten the range.
Old Jan 16, 2019 | 03:32 PM
Originally Posted by oth
In a car with an alarm, the key fob communicates with the alarm control unit rather than the keyless entry unit - if it's hidden in a more electrically shielded area (likely), it will shorten the range.
Not in my case, my fob is still attached the factory alarm. I'm about to post a different thread about it.
Old Jan 17, 2019 | 07:41 AM
oth's Avatar
oth
see my answer in your other thread
aznsupastar
Jan 31, 2020 12:19 PM
caseh
Apr 22, 2013 03:03 PM
Knappster
Jun 28, 2007 06:53 PM
BORT617
Jan 19, 2007 11:04 AM
ED1
Dec 23, 2005 02:35 PM
