Lightbulbs
Old Jan 8, 2007 | 07:47 AM
bcs's Avatar
bcs
Please post some pictures once you get the new bulbs. I'd be interested in seeing how this turns out.
Old Jan 8, 2007 | 09:34 AM
USMC2006s2k's Avatar
will do~!
Old Jan 9, 2007 | 07:24 AM
okay...so how the heck do you change out the bulbs....i know...noob question......oh and i bought the silverstar bulbs ....cost me dang $40....psh...hope they look good....but yeah.....do i need to take the whole dang bumper off or something?
Old Jan 9, 2007 | 08:36 AM
Picturepro's Avatar
First Do passanger side is the 6-7" hole, you will get the hang of it and will be able to see alittle
Then Drivers side remove the overflow for radiator, this side will by feel only
take your time
Old Jan 10, 2007 | 10:05 AM
okay, at the risk of sounding like a complete idiot...is there any thing out there that would show me step by step how to take the dang highbeam bulb out? i feel like a monkey trying to *uck a football....(marine term sorry)
Old Jan 10, 2007 | 01:12 PM
GranPrix's Avatar
No matter what halogen bulb you buy, it will ALWAYS look like that dark yellow/amber color when running at 60% power.
The Sylvania Silverstars will look just like the stock bulbs do when the DRL's are on. The only difference will be when you have your highbeams on. But I hope you don't drive around with your higbeams.
Old Jan 10, 2007 | 03:42 PM
SheDrivesIt's Avatar
Isn't that what they are for? Do you just use them to signal oncoming drivers of a law enforcement officer in the area or to ask people to move over to allow you to pass?
Old Jan 10, 2007 | 03:43 PM
Spec_Ops2087's Avatar
Changing the bulbs is a pita because there is hardly any room and you can't see what your doing...must do it by touch.
Basically, you loosen and take off the weather seal. Then pull off the harness on the back. Next you must feel around and unhook the little metal clip that holds the bulb in. Take out the old bulb and put the new one in. Reattach the clip and place the weather seal back; retighen.
Its fairly straight forward, but as I said, a pita to actually do.
Old Jan 10, 2007 | 07:07 PM
i knew it was gonna be a pita but now i'm not even sure if i wanna go through with it cause grandprix said there isn't gonna be a diff.... stupid dang bulbs....maybe i should just put in real hids and forget the DRL....what do you guys think?
Old Jan 10, 2007 | 07:28 PM
Your going to run real HIDs in in the high beam section of the headlight in a drl mode? Doesn't sound to bright to me...pardon the pun
