Lightbulbs
Old Jan 6, 2007 | 07:33 PM
USMC2006s2k's Avatar
Post Lightbulbs
i'm looking to replace the factory DTRL with something less...."stock"....i know that most people on this site are about performance and stuff, but i don't really like the way the factory bulbs look...plus they really don't match the headlights. i know that i can replace the bulbs with true HIDs, but i heard that i will lose my DTRL...is this true? any help would be great. thank you so much.
Old Jan 6, 2007 | 08:19 PM
darkknight1999's Avatar
DTRL?
Old Jan 6, 2007 | 08:41 PM
sorry...Daytime Running Lights....probably should have put DRL huh?
Old Jan 7, 2007 | 04:34 AM
NFRs2000NYC's Avatar
Someone refresh my memory....the S2000 DRLs are highbeam bulbs with low wattage correct? Meaning, its the same bulb as the highbeams....?
Old Jan 7, 2007 | 08:46 AM
Spec_Ops2087's Avatar
Correct, I believe they run at 60% power when they are DRLs and then (obviously) 100% power when you activate the high beams.
Old Jan 7, 2007 | 12:56 PM
Then you can only replace them with something like Silverstars.
Old Jan 7, 2007 | 06:01 PM
okay so i got that i'm not going to be able to change out the bulb with true hid...now what bulb should i use...silverstar is what i run in my Yukon(yeah i know), but will it match the purpleish hue of the hid or is there something else that i can use on them to better match the low beam color? thanks any help would be great
Old Jan 7, 2007 | 06:13 PM
well are your trying to make the DRL mode match your HIDs or the high beam mode?
It'll be impossible to change the "DRL mode" color since the light is running at 60% of its brightness no tinting on the bulb will help as its not bright enough to show the different hue.
If you want the "high beam mode" to match the HIDs, you could get some silverstars. They are a a little bit more white, but nothing to go crazy about.
The only real way to match the color is to get another HID system in there which, obviously, wouldn't be recommended.
Old Jan 8, 2007 | 01:49 AM
Silverstars are the closest thing to HID that you can get from a halogen. Be VERY careful buying those POS japanese knockoff HID blue tinted lens 500000million watt bulbs. They WILL melt your housing.
Old Jan 8, 2007 | 07:30 AM
thanks for all the help guys....i guess i'll buy some silverstars and see how they come out
