under? not a chance. i just put a similar one under the seat of my baja and had to cut the bottom out of the seat metal bucket and it barely clears. that car has twice the space under the seats as the s2000.
either behind and lose the leg room. or a custom trunk/footwell setup. i went with the trunk well for the wife, its barely useable space anyways.
I installed that exact unit, and it takes up zero cabin space, install invisible.
I put it under passenger carpet, footwell area. There is a large foam wedge under there, and about an inch thick soft foam under that. I cut a slot in both the size of this unit.
Did all the wiring, routed control remote over to drivers underseat area, with enough slack you can reach down and pull out to use.
Carpet sticks up about half inch at very top of carpet, but you can't see unless really know where to look.
Class D, so no heat to worry about.
wow awesome! that's mega helpful! any pics of reference links?
