Max speaker depth for door speakers
Old Feb 21, 2014 | 07:55 AM
LookingForS2K's Avatar
Default Max speaker depth for door speakers
Im considering upgrading my door speakers to these:
http://www.amazon.com/Infinity-Refer...3001437&sr=1-5
But im not entirely sure theyll fit w/out modification. Anyone know the max depth that we can run in the doors? Thanks!
Old Feb 22, 2014 | 10:55 PM
Ragnarok043's Avatar
the speakers in my car has a mounting depth of 3.14 inches and the magnet has a diameter of 4.76 inches. the magnet barely fit though the stock opening and just clears the window with a 3/4 inch mdf spacer. the only modification that i had to make was to trim the plastic on the door card behind the speaker grill to allow for about 1/2 of speaker excursion.
Old Mar 6, 2014 | 06:48 AM
Bump. Anyone have experience with the ones I linked?
Old Mar 7, 2014 | 12:33 AM
those speakers have a mounting depth of 2.06 inches and the diameter of the magnet is 3.56 inches
Old Jun 21, 2014 | 10:34 AM
S2kmybabe's Avatar
Did you endup with these?
Old Jul 3, 2014 | 11:02 AM
PorgyS2K06's Avatar
Just for edification's sake, the 3/4" space brought the speakers forward enough to clear the window coming down? How close did that bring the cone to the door panel? I need 3.7" mounting depth and was REALLY hoping to avoid cutting doors and glassing.
Old Apr 21, 2020 | 02:10 AM
aussie2k's Avatar
I'm curious also, as I'm wanting to install some focal components that are 3.08 inches mount depth.
According to Modifry, with 3/4'' spacers you have 3.12 inches to play with.
Although the earlier post said 3.14'' speakers will fit?
https://modifry.com/index.php?route=...product_id=191
Old Apr 21, 2020 | 07:23 PM
windhund116's Avatar
Maybe, send Modifry an email about the fit. With specific Focal model and their adapter?
Old Apr 24, 2020 | 11:40 PM
so the exact speakers that i run are KRX3 the spec sheet lists it as 78.8mm depth here https://www.focal.com/sites/www.foca...t-165-krx3.pdf
the speakers you're looking at are listed as 77mm depth https://www.focal.com/sites/www.foca...ical_sheet.pdf
biggest issue i had was clearing the door card, it was very close to the inside bottom corner. i trimmed the MDF ring to the exact diameter of the speaker and mount it as high and back as possible. also trimmed the plastic in back of the door card as previously mentioned
RoG_Renegade
Aug 24, 2017 12:18 PM
dsthez
Dec 6, 2012 10:29 PM
etang789
Feb 8, 2011 06:26 PM
Mooms
Feb 11, 2005 08:18 PM
00SType
Jul 9, 2001 06:29 PM
