Modifry IR DCI
Old Nov 25, 2007 | 10:38 AM
street_ruler's Avatar
Default Modifry IR DCI
ive been looking into a new headunit and i want to run the modifry DCI. the question is, with the IR one can you use your dash controls with the radio door closed or does it ahve to be open?
I just hate the way the car looks with the radio door open
Old Nov 25, 2007 | 10:46 AM
kenta's Avatar
Should work even better with the door closed as there would be no interfering light hitting the IR sensor.
Old Nov 25, 2007 | 01:28 PM
Saki GT's Avatar
Old Nov 25, 2007 | 03:48 PM
i thought it would be an issue with like line of sight or soemthing....but it works better? can anyoue confirm this that has an IR DCI?
Old Nov 25, 2007 | 04:58 PM
DBXFX's Avatar
The IR LED in usually mounted inside the door above the HU pointing downwards. So in this case, the door closed would only help the reception. The only time I think the door would interfere is if you mount the IR outside the the radio area like in the center console or something, but other than that, I think your good
Old Nov 25, 2007 | 08:33 PM
stopmenot2002's Avatar
this in mine on white masking tape on the radio door its open and close fine, works both way It will be heat shrink wire black soon.
46&2
Oct 23, 2017 05:11 AM
ajmarkwick
21
Nov 20, 2006 11:00 PM
Nishant
Oct 21, 2004 03:50 PM
palsor
Aug 4, 2004 03:47 PM
Celeritas
Nov 11, 2003 06:11 PM
