Monster Power Cable - where/how to mount fuse?
Installed Monster power cable and getting ready to install amp this weekend. The plastic fuse holder has 2 screw holes to mount inside the engine compartment. Where has anyone else mounted this? Drill into the body? Need a good solution.
I get very nervous about making more holes in the body as it leads to potential rust spots down the road (no pun intended). The above two suggestions are good enough, but if it really bugs you, make a nice bracket that becomes more of a showcase piece, and mount all of your stereo fuses to that.
i just did this tonight. there is a mounting spot right in front of the right front bolt for the fuse box(as you are looking at it from the front). zip tie on both sides of the plastic mount right to that bar longways. run the wires underneath the fuse box. no holes and looks professional.
[QUOTE]Originally posted by 1a-race
[B]i just did this tonight. there is a mounting spot right in front of the right front bolt for the fuse box(as you are looking at it from the front). zip tie on both sides of the plastic mount right to that bar longways.
THAGR81
Aug 7, 2002 10:49 AM
