Mounting Amp behind seats
The only issue I see with behind the seat mounting is that the seat should be able to go that far back regardless. What if you need to have some guy with long legs drive your car? The steering wheel is not movable in this car and some guys can't bend their knees to fit let alone drive safely. That and water can be more of an issue, seems like a sudden rain with the top down can short your amp.
What do you guys think about mounting an amp below the cover in the trunk well, where the tool kit is? Possibly the tools could then be stored in the cavity to the left of the spare tire (not in their original box). This was proposed to me, along with perforations in the lid to allow the amp to breathe. Would like to keep the spare, tools, and not compromise trunk space.
as the well is needed to carry your flat tire if you are using the space-saver spare.
An amp shorter than about 15" and less than about 2-1/2" thick will fit above the gas tank
to the left of the spare tire. Not all amps may be thermally happy in this area, though a
wide variety of amps have been successfully mounted here. Here is one relevant thread.
Yes, you need to remove the tool kit too. The manual suggests putting it
where the spare was.
The giant PITA is that if it's your rear tire, you need to put the spare
on the front and the front on the rear... Fortunately that hasn't ever
happened to me.
happened to me.
Yes sir, but I've since changed them out to the newer bigger better version, the BG Neo10. They sound fabulous. The UL12 is one of the most advanced subs on the market but imo you are going to have a hard time in this application. The low end rolls off sharply and you can never have a big enough box for it, the Q is near 1 from the get go. The parameters seem to be made to resist power instead of making best use of it. Too bad as it's a killer sub on the bench, I think probably the best ever, just no real application where it would work lol.
I had some listening time in a car with 1 of the UL12's mounted in a sealed box with a mmats 3500.1 pushing it and I was impressed at how low and loud it got. I picked this one up in a trade cause the owner blew the tinsel leads (tested good with dmm) which seems to be a common problem when running these with shit loads of power for long periods of time. My 55lb 15" sub just wasn't going to work in this car so it was either one of the low powered jl audio (or something similar) enclosures or grab the UL12 and see what happens.
