Mounting woofer to sealed enclosure
Old Mar 19, 2010 | 12:12 AM
tbonesteak's Avatar
Default Mounting woofer to sealed enclosure
Hey guys,
I'm about to mount my fosgate sub into the sealed enclosure i got. The box came with no wires, gasket, plug, but it does have the terminal cup mounted. The entire box is carpeted.
1. What gauge wires should i use to connect the sub to the terminal cup?
2. Do i need to buy some plugs to connect the wires to the terminal cup? Banana plugs maybe? i know that you directly insert the wire into the subwoofer but to the terminal cup, it seems like i need some kind of a plug to connect it.
3. Do i need some sort of a rubber gasket or a seal to put between the sub and the box to ensure an air tight fit? I don't want a leaky setup. If so, where can i get one? FYI, the entire box is covered with carpet, even where the screws would go in to mount the sub.
Thanks in advance.
Old Mar 19, 2010 | 12:42 PM
2big4aS2000's Avatar
10-12 guage wire will work ok
i solide to terminal cup and then most subs has push type connectors
no gasket, the carpet will work like one.
Old Mar 19, 2010 | 02:01 PM
tbonesteak's Avatar
Thank you sir.
hybridcmk
Feb 15, 2010 11:37 AM
SilverstoneS2k_FL
Feb 25, 2005 07:16 AM
SCoach
Jun 9, 2004 07:18 PM
redleader
Nov 26, 2002 05:25 PM
