Mute Button light stays on!
Old May 15, 2001 | 09:24 PM
cmccarrick's Avatar
After installing the PAC mod and the mute button control, whenever I hit the mute button, I could hear the relay clicking, but the sound would not be changed. After a few times of doing this, the mute button seems to be locked in the "On" position. (The green light is on). Since it did not work to begin with, the is still sound at least. Any ideas on how to fix this? I already tried disconnectin the mute lead to the relay. No luck.
Thanks
Old May 16, 2001 | 09:18 AM
bbsilver's Avatar
[QUOTE]Originally posted by cmccarrick
[B]After installing the PAC mod and the mute button control, whenever I hit the mute button, I could hear the relay clicking, but the sound would not be changed.
Old May 20, 2001 | 05:42 PM
NSXS's Avatar
One thing to careful of when installing the PAC mod with relay, is the coil current used by the relay. Some 12V relays have coil resistances of less than 100 ohms. A 100 ohm coil would try to draw 120 ma from the mute circuit when switched on. I wouldn't doubt that could burn out the circuit. I would recommend a coil resistance of greater than 800 ohms. That would draw 15 ma or less which is probably fine. The relay switching current isn't important since the the mute inputs on car radios draw little current.
Old May 21, 2001 | 06:26 AM
MacGyver's Avatar
[QUOTE]Originally posted by NSXS
[B]One thing to careful of when installing the PAC mod with relay, is the coil current used by the relay.
ThatPreludeGuy
Jun 2, 2008 01:19 PM
peteyfoot
San Diego S2000 Owners
24
Feb 20, 2008 05:57 PM
Apee Two
Aug 1, 2007 10:40 PM
dmw16
Sep 30, 2006 04:22 PM
Runaround
Jul 7, 2003 03:38 PM
