need help with alarm problem
Old Jul 26, 2006 | 09:55 AM
Syncro9z-S2K's Avatar
Default need help with alarm problem
i went to my car this morning, unarmed the alarm, but noticed something weid, the led alarm was still flashing. opened the door and alarm went off, tried to disarm with remote, tried to unarm by putting key into the ignition, nothing worked, alarm kept going off...tried to look for mayb a burnt fuse, no luck, unhooked the battery, not luck, this is the weidiest thing that has ever happen, i have no cluw why the larm would not turn off.finally looked at my manuel and found the disarm valet switch..the alarm is off now, but i have no clue on how to arm the car again. can someone help please.
Old Aug 19, 2006 | 05:29 PM
imdarkrider's Avatar
Sure , Couple of things , Try re-programing your transmitter remote. If that doesn't work , or it's not reading the remote then you need to check your antena , check to see if it's plugged in at the reciever , then check to see if it's plugged in at the brain. If it's none responsive you either hav ea bad transmitter , or a bad antena , also I don't think your this much of a noob but check your battery :-)
Calzonii
Mar 30, 2017 10:32 AM
razzele
Apr 20, 2013 12:31 PM
Nickamsweet
Jan 31, 2011 01:58 PM
Suzybee
May 2, 2006 07:41 AM
gmans2000
May 15, 2005 07:10 AM
