Need help with rear tray
This may be a stupid question. Did a search but nothing. How do you get the rear tray out past those metal buttons that hold the soft top tonneau cover? Any help would be appreciated.
I just did this a few days ago so here's my take.
1) Push in the center pins for all the buttons that are in the tray. This will allow you to easily pull it out. I believe there are 4 near the roll hoops and three on the opposite end
2) Toward the rear of the tray you'll see a plastic cover directly above it (about 3" wide and 3 feet long). Gently pry one end and it should gradually snap out.
3) Now pop the trunk and remove the trunk lining and release those white tabs you see hanging down. Once the tabs are released, gently hit the tray upwards and it should pop up.
Thats it! I must warn you that putting the tray back in is real difficult, especially when putting back the plastic cover.
