Need Help Reinstalling Factory Radio
I attempted to remove my JVC KD-AVX1 to reinstall the factory radio this afternoon but noticed that the factory harness had been modified. Here are some pictures of the configuration currently:
The previous owner installed the deck so I'm clueless as to his methods. How should I install the factory radio in my current condition? Thanks guys!
Well, it looks like there is enough room left with the wires in the connector that you can strip back the insulation and solder the wires from the vehicle harness back to the vehicle connector. Then, you'll be squared away.
Looks as if they decided against using an adapter harness and vut directly into the stock one
just strip, solder, shrink wrap, repeat for each wire
