Need help srs off
Old Aug 6, 2013 | 01:22 PM
  #21
BLAQ&GREYs2k's Avatar
Originally Posted by freespace303
My srs light is stuck on. I have power/audio cable run from the headunit to where the modifry dash bracket goes, I was pulling on one of the cables to get more out (upgrading from iphone to samsung galaxy phone dock) and now the srs light is stuck on all the time. Could I have pulled a srs cable? Is there an easy way to reset it to see if it's just that? (like the maint light) Or am I stuck with pulling out my dash to figure out this elusive problem?
If you look back a few posts you will see the SRS module is located directly underneath where the head unit goes. I would check to make sure the connector is plugged in and none of the wires have been stretched or pulled out. If it wasnt on until you ran the modifry thing thats your issue.
Old Aug 9, 2013 | 08:20 PM
  #22
freespace303's Avatar
Thanks, I'll have to check that out.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Old Aug 14, 2013 | 09:12 AM
  #23
Agc1's Avatar
Hey blaq&grey I got my seatbelt tensioner and srs module back. I've installed them, when I connected the battery and put the ignition on 2 the Srs light stayed on. I proceeded to do the Srs reset by jumping the two wires in socket in the fuse box. The only difference now is that at the end of thee jump the Srs light blinks twice and shuts off. But when I take the keys out and place ignition on 2 again, the Srs light comes back on and stays on. Any ideas on what to do from here. Thank in advance for any reply.
Old Aug 14, 2013 | 10:38 AM
  #24
Agc1's Avatar
I also jumped odb2 pin #4 and 9. It gives me 4 long blinks followed by 2 short fast ones.
Old Aug 14, 2013 | 01:59 PM
  #25
Im not sure about the pin jumping, but if you completely neutralize the voltage in all of the modules they should reset. What I mean by this is, unhook the positive and negative lead from the battery. Clamp the two leads together (not the battery!) and let them sit for about 5mins. Doing this will kill all the voltage in the modules, harness, ecu, etc. This should mimic a scan tool going in and clearing the SRS module codes.
Key on engine off the SRS light should light up btw. It should also light up briefly on start up then go out.
Old Sep 2, 2013 | 08:05 AM
  #26
Agc1's Avatar
Hey blackandgrey do you know if an 05 seatbelt will work with my 02? Or do they change at a certain year?
Old Sep 4, 2013 | 05:59 PM
  #27
Not entirely sure. I would use a site like majestic honda and compare both part numbers. if they are the same i see no problem
Old Sep 16, 2013 | 11:55 AM
  #28
andrew87890's Avatar
my SRS light is on all the time, just bought the car it stays on while driving. just went to honda they want 100$ to dinag the problem. what could be the cause of this?
Old Sep 16, 2013 | 12:10 PM
  #29
just scaned my car would a 61-01 code have anything to do with SRS, said something about ABS low voltage
Old Sep 16, 2013 | 12:28 PM
  #30
davidc1's Avatar
Nothing personal here andrew...but, you bought a used car knowing the SRS light was on? No a great move there.
Could be something unplugged and all you gotta do is plug it back in....could be it's missing both airbags and it's cost you $1000 or more to fix.
I'm not sure, but I don't think the ABS would have anything to do with it. But, now you may not have functioning ABS. Almost as important as an airbag. Was the check engine light on as well when you bought it?
