Need help troubleshooting problem
Old Apr 7, 2006 | 08:37 PM
00S2K01S4's Avatar
Default Need help troubleshooting problem
I'm wondering if I don't have a good enough ground. Here's the problem. With the engine off, I am reading ~12v to the dist block, and both amps terminals. If I turn on the radio,, it drops to ~6v at those points. If I remove a remote wire from one of the amps, it goes to ~8v. What's going on?
Old Apr 7, 2006 | 10:11 PM
boyguan's Avatar
if your unsure of a ground, just redo it.
ground wire should be same thickness as the power wire and the surface should be stripped of paint to be safe. i usually dont use a bolt but rather use some self tapping screws
Old Apr 8, 2006 | 05:57 PM
Dcon67's Avatar
Sounds like a bad battery to me, I'd get it load tested.
Old Apr 8, 2006 | 08:37 PM
00S2K01S4's Avatar
Thanks for the tips. Checked everything. I bought a new battery recently so it wasn't that. It was a bad ground. Everything sounds great.
crank
Jul 12, 2013 05:51 AM
Gatsbee13
Aug 17, 2010 09:34 PM
00S2K01S4
Mar 15, 2006 11:25 AM
Thistler
Aug 19, 2005 09:45 AM
Notion
Sep 13, 2002 05:23 PM
