Need some guidance (amp removal)
Old Apr 10, 2010 | 07:42 AM
S2K Type R's Avatar
Default Need some guidance (amp removal)
To the audio gurus, I bought my car used with an Alpine H/U and a cheap MTX amp but no subwoofer. Right now, it is stuffed in the spare tire cargo area.
I don't play loud music but would like to keep H/U. Should I remove the amp or is the power draw insignificant? If yes, how do I do it properly? Is it just a matter of disconnecting all cables or is it more complex like re-wiring the H/U and speakers?
I also read that I need to disconnect power fuse. Where is this?
TIA
Old Apr 12, 2010 | 12:14 AM
Juice Steez's Avatar
Hey there, I would check the amp to see if its running the speakers because if it is then you might want to keep it. If you remove it you will have to do some slight re wiring to have the HU power the speakers.
Old Apr 12, 2010 | 01:20 PM
S2K Type R's Avatar
Thanks for the reply. I found the fuse for the amp and disconnected it. You're right, with the amp powered off, I get no sound from any speakers. I was hoping the previous owner just used the amp to power a sub.
Can I just splice the front/rear speaker IN wires with the corresponding OUT wires that enter/exit the amp?
Old Apr 13, 2010 | 10:00 AM
If he is running the speaker wires from the Speakers to the AMP then you need to run them to the HU, If he grabbed the signal from the OEM harness the you just need to rewire them to the HU harness. If this sounds ambiguous let me know and I'll explain some more Some times I wish I had one of those boards that John Madden uses then boom!
Old Apr 13, 2010 | 09:06 PM
S2K Type R's Avatar
Thanks again. The wiring kind of looks like this from memory. Since the HU is powered even when I disconnect power to the amp, can I connect the yellow line from the HU to the magenta lines that go to the speakers?
I'll try to take some real pics.
Old Apr 14, 2010 | 07:03 AM
oth's Avatar
oth
If the amp is connected to the headunit by RCA cables, as in this diagram,
you can't connect them to the speaker wires as you proposed because
the signal is a preamp signal not powerful enough to drive speakers.
Some amps can accept speaker-level inputs, though, and if it was wired
that way, with speaker wires headed from the headunit into the amp, you
could connect speaker wire to speaker wire, bypassing the amp.
Unfortunately, there are a lot of different ways things could have been
wired.
a couple questions to answer:
1) is the amp connected to the headunit by RCA cables or speaker wires?
2) do the speaker wires coming from the amp go directly to the doors, or
are they connected back into the car's harness, thus entering the doors
through the stock wiring?
Old Apr 16, 2010 | 11:16 AM
S2K Type R's Avatar
wired.
Hi,
Thanks. I'll try to find time to trace the wires and also take some pictures.
The speaker IN wires are terminated with RCA into the amp and the OUT wires use a screw clamp, if that helps in any way There's also a light blue connector which looks very OEM which is not connected to anything. I'm wondering if this is the extension from the OEM wiring harness.
Appreciate the help, will follow-up with more info.
CreAziaN
Jun 25, 2010 10:34 AM
nMeOnE
Apr 20, 2008 05:51 AM
aggie
Feb 3, 2005 01:30 PM
kw2000
Jan 15, 2005 07:03 PM
ErikKlenke
Jul 16, 2001 01:00 PM
