Negative Trunk Release Wire / Hood Pin Wire
Old Aug 29, 2008 | 10:47 AM
mrpoopiehead's Avatar
Default Negative Trunk Release Wire / Hood Pin Wire
Hey everyone, I am currently installing an alarm, and I was wondering if there is a negative trunk release wire in the car. On the wiring diagrams online, it says there is a positive trunk release wire at the keyless entry module, but if I use that wire, I will have to connect a relay to it.
My other question is, where is the wire for the hood pin located?
Old Aug 30, 2008 | 10:56 AM
HankookS2K's Avatar
you have to use a relay for the trunk. there is only a positive.
Old Aug 30, 2008 | 08:12 PM
DBXFX's Avatar
i'm not sure the hood has a pin switch... it doesnt have a light that it would control ???
Old Aug 31, 2008 | 11:48 PM
Stealth_SUX_'s Avatar
There would only be a hood pin switch if you have the factory honda alarm installed..
Other than that just make your own with a new switch
Old Sep 3, 2008 | 06:42 PM
Thanks for the replies guys. I'll just wire up a relay for the trunk release and for now not worry about the hood pin switch for the time being. On the other hand, there is a trunk trigger wire that triggers the alarm if someone pops the trunk right?
match417
Jul 13, 2015 03:07 PM
s2ki_control
Mar 26, 2009 06:21 AM
nazaracing
Mar 29, 2008 09:15 PM
SandyS2K
Apr 24, 2004 10:14 AM
SandyS2K
Apr 22, 2004 05:03 AM
