Neo 35 onboard
Old Feb 21, 2001 | 02:39 AM
AusS2000's Avatar
I finally got through all the technical hurdles of installing the Neo 35.
The answer to all issues appears to be good power.
I now have a separate power line to the Neo in the trunk, the amp under the seat, and this week I'll run another line to the head unit.
I'm even going to run another line and RCA's to the trunk in expectation of a powered subwoofer.
Oh, of course all components need to be properly mounted and wiring cleaned up, but you get the idea .
Old Feb 21, 2001 | 07:54 PM
AusS2000's Avatar
I went driving for about an hour today and the Neo is truly revolutionary.
It doesn't skip, even on the roughest roads, and holds more songs than I'm likely to get through this millenia.
Now if I can only find somewhere to mount the control panel.......
Old Feb 22, 2001 | 07:18 PM
Mindcore's Avatar
Somebody mounted the control behind the shifter where the Change holder is. It looked really slick. Although you have the Headlamp Washer control there don't you? Might be a good excuse to get rid of them
Old Feb 22, 2001 | 07:23 PM
AusS2000's Avatar
That was the idea, but it's a bad position because you have to elbow your passenger to control it.
It was Wesmaster that did this install and I also remember he managed to break the joystick which is probably due to it's position.
Also, you have to do some hacking to fit it in there as it's too wide. The newer remote is narrower (4mm too wide) and doesn't use a joystick so I'll order it and try to install.
Old Mar 7, 2001 | 09:49 AM
Wesmaster's Avatar
I have a Neo also, love it - not sure how I lived without it. Check out my install.
Wesmaster
FastAP2
Aug 1, 2017 12:31 PM
X100
Jan 2, 2014 11:54 AM
1st07inOH
Nov 30, 2007 08:45 AM
golfpro
Jul 29, 2006 10:53 AM
j_c_a
Jul 16, 2005 04:43 AM
