New Box
Old Sep 2, 2007 | 05:26 AM
S2Kstuntin's Avatar
Default New Box
I am going to be building a box for my W7. I am most likely going to use fiberglass for the box
The sub unported requires 1.2 cu/ft and ported requires 1.5cu/ft.
I want to get as much as much spl out of the sub that I can since it is only going to be one 10". I was considering porting the box.
Any ideas?
Old Sep 2, 2007 | 09:18 AM
sixsevenone's Avatar
goodluck!
wouldnt recc. fiberglass..
that subs pretty powerful..
considering it needs a double wall for the face on a normal mdf enclosure!
Old Sep 2, 2007 | 11:21 PM
DDuds2k's Avatar
why would fiberglass be no good? The sub would crack it? Or just not good for sound?
Old Sep 3, 2007 | 04:50 AM
S2Kstuntin's Avatar
I would like to know this as well.
Old Sep 3, 2007 | 05:54 PM
imdarkrider's Avatar
it'll crack... but if you went with an 8'' you'll be fine... if your going to do the 10 I strongly suggest at leassstt 8-10 layers of fiberglass matt , followed by a layer or 2 of Rage gold (stonger bondo)
Old Sep 3, 2007 | 07:34 PM
S2Kstuntin's Avatar
I was only planning on fiberglass so I could get the most space possible out of the tool area in the trunk.
Would I just be better off using MDF? If so what thickness?
Old Sep 3, 2007 | 07:35 PM
S2Kstuntin's Avatar
BTW, I already bought the 10"
Old Sep 3, 2007 | 08:37 PM
RCHB's Avatar
12w7 > 10w7 . i made the box myself.
its a little less than 1/4 in. thick fiberglass, and double baffeled 3/4 mdf.
only problem is the lack of trunk space.
Old Sep 3, 2007 | 09:28 PM
DDuds2k's Avatar
man....isnt that a little unnecessary? Your car must slam. Nice work though.
Old Sep 4, 2007 | 04:26 AM
by double baffle he means that there's 2 peices of 3/4'' MDF put together to make the front - the part the sub is screwed to.
