New Stereo no power
Old Dec 13, 2012 | 09:08 AM
zenbone's Avatar
Default New Stereo no power
i took out the OEM stereo and put in a new Alpine. The wiring harness was easy enough but the stereo won't power up. when i put the old stereo back in i entered the code and it works. Do i have to do something with the anit theft wiring or could it be something else. i do not think the Alpine unit is bad, it is their high end model and it is brand new. Any thoughts? anyone?
Old Dec 13, 2012 | 09:10 AM
JohnsS2000's Avatar
you probable have your power and ignition source reversed of how they should be. I have an alpint HE and used a "go between" harness to plug n play
Old Dec 13, 2012 | 09:11 AM
JohnsS2000's Avatar
dont match up your wires based only on color
Old Dec 13, 2012 | 09:20 AM
zenbone's Avatar
i used a go between harness and matched up the wired by function. the wire colors were dead on, only one i didn't use was a remote wire. Could the go between wire harness be bad?
Old Dec 13, 2012 | 09:35 AM
zenbone's Avatar
FOUND IT... i called the harness place and they said to check the fuse on the fuse block. Turns out the factory stereo will still fire up with a blown fuse when the after market stuff won't. who knew. (>.<)
TookayS2K
Feb 4, 2009 07:16 AM
nazaracing
Jun 10, 2006 06:05 AM
CarmenOhio
Mar 20, 2006 05:18 AM
kev1025
May 19, 2005 09:16 PM
kev1025
May 7, 2005 04:55 PM
