No AM reception. FM fine.
Old Aug 17, 2004 | 08:00 PM
norcalskier's Avatar
Default No AM reception. FM fine.
I just upgraded to the Alpine CDA-9831 and I'm having one problem. I'm receiving FM reception with no trouble, but no AM reception. I didn't have this problem at all with the stock deck. I pulled the deck out and verified the antenna cable had a good connection. Is there anything else that I can check? The owners manual only mentions to make sure the antenna cable has a good connection. Not sure what else to do.
Thanks for the help.
Jerry
Old Aug 17, 2004 | 09:08 PM
Chadwick's Avatar
Jerry
The Alpine wire harness or something is basically missing a needed connection. The S2000's antenna has a powered amplifier whenever the radio is turned on. Your FM reception is there, but it's probably not as good as it could be, and your AM is worthless until you connect the power antenna lead up so that it gets power when the radio is on (or a constant with the ignition, not sure which my installer did).
Once you do that, your radio will be back to normal. Try a search or look back a couple of pages. Nice post at the top of Electronics forum about 2 1/2 weeks ago about it.
Old Aug 18, 2004 | 08:01 AM
johnnydev's Avatar
Chadwick is right on. Only I think it's most or even all aftermarket head units because my Pioneer has the same issue. I also think that Modifry or MacGyver have a "how-to" posted on thier web site. A search of the electronics forum on something like" AM power" should yield a wealth of info.
Old Aug 18, 2004 | 11:12 AM
Thanks for the advice and suggestions guys. I will see if I can find that other post and also look at "how to" section at Modifry again.
Of course the server is down right now so I can't search for "am power"
I'll have to try again later.
Thanks,
Jerry
Old Aug 18, 2004 | 11:20 AM
s2kdarren's Avatar
please post your findings...
Old Aug 18, 2004 | 11:38 AM
PokS2k's Avatar
Thanks,
Jerry
It is really simple. You need to attach the Power Attena wire.
Power Antenna
The FM will improve too.
Old Aug 18, 2004 | 06:48 PM
I'm in business Everything is sounding good.
Yep, just that one little wire. But this novice didn't know it was important
Thanks guys for the help on this one. It is much appreciated.
Jerry
Old Aug 18, 2004 | 06:52 PM
Chadwick's Avatar
Jerry
From the number of threads on the subject, apparently more than just novices are missing it.
Glad you got it working. How do you like your new H/U?
Old Aug 19, 2004 | 07:20 PM
It is a big improvement over the stock HU. I like the extra power it has, but I will probably still add an amp in the near future. I also bought the S-Pods at the same time and had Crystal CPE-50's installed. They sound great and it is so nice to be able to hear music and AM talk while driving on the freeway with the top down.
I don't like that the Alpine doesn't have a simple bass and treble button, and I'm not sure how the i-personalize will work. I looked at the web site and I might play with it soon. Has anyone else used this feature?
I'm really looking forward to adding XM to my system. Hopefully that new XM receiver with Alpine adapter will come out soon.
LateBrake
Mar 15, 2010 05:22 AM
lecter255
Dec 12, 2009 11:34 AM
DWynne
Aug 1, 2005 10:53 AM
Y2K1S2K
Jul 21, 2004 10:18 AM
burnmacs
Apr 7, 2004 08:01 AM
