No "Code"
Old Oct 11, 2019 | 09:57 AM
gerry100's Avatar
Default No "Code"
Taking a long ride tomorrow and though I'd reactivate the radio after battery replacement.
"Code" prompt DOES not appear, entering 5 dig code does not have any effect.
Since I haven't turned on the radio in years, I guess it could be a fuse, if that's the case I'll need some guidance on opening the fuse box without breaking nanything
Thanks for your help
Old Oct 11, 2019 | 02:47 PM
gerry100's Avatar
Changed a good fuse for a new one.
Radio lights go on with the int lights but the LCD display is dark and blank. Entered the code anyway with no result.
Ideas? Thanks
Old Oct 12, 2019 | 05:39 AM
SheDrivesIt's Avatar
Does your convenience socket ("cigarette lighter") work?
Old Oct 12, 2019 | 06:39 AM
gerry100's Avatar
Don't have a device to test for juice, but I assume you're suggesting replacing the 10a fuse?
Just making sure before I put the old bod thru more painful garage yoga.
( not important, but for laughs can somebody tell me why the manual suggests you "turn the knob" to open the fuse box? It does nothing as far as I can tell)
Old Oct 12, 2019 | 10:26 AM
gerry100's Avatar
BINGO!
Never would have figured that out.
Thanks
Old Oct 12, 2019 | 10:34 AM
Chuck S's Avatar
How are you getting to the fuse box on the driver's side? The panel hiding the fuse box is secured by a twist knob (maybe two). See the illustration on page 186 of your 2006 owners manual.
-- Chuck
Old Oct 12, 2019 | 10:43 AM
gerry100's Avatar
Chuck- I turned the Knob and it does nothing and realease nothing.
Got to the FB thru painful contortions basically standing on my head in the footwell. Just under 6 ft and 200 lbs, a little thick but not much bigger than average.
Maybe the sick designer that came up with the secret compartment did the "knob" too
I went under the "panel" because it wouldn't come loose an dI didn't want to force/break anything
Old Oct 12, 2019 | 11:19 AM
Chuck S's Avatar
I think ya have to twist and then pull both knobs off to remove the panel below the steering wheel. They may unscrew. You're better at "dashboard yoga" than I.
Sounds like you fixed the problem. I fully understand not using the radio. I forget it's there.
-- Chuck
Old Oct 12, 2019 | 11:50 AM
gerry100's Avatar
BOTH knobs ?
Old Oct 12, 2019 | 11:58 AM
Chuck S's Avatar
I believe there's one on both sides of the steering wheel securing the modesty panel below the steering column area of the dash. I'm not where I can get to the car right now.
-- Chuck
matthewLC
Apr 22, 2019 07:08 PM
Curated Content Editor
Mar 20, 2019 09:44 AM
andrewv
Jun 29, 2018 07:43 PM
liquid_helix136
Feb 14, 2018 02:26 PM
Babbage
Jan 17, 2018 04:54 AM
