OEM Headrest speaker question
Old Jun 3, 2006 | 12:00 PM
Kabomo's Avatar
Default OEM Headrest speaker question
I was wondering if anyone knew what the wattage for the OEM headrest speakers are. Anyone think it's a good/bad idea to hook them up to an amp?
Old Jun 3, 2006 | 12:40 PM
NFRs2000NYC's Avatar
If you want to toast them, sure. They are nothing more than glorified tweeters, and will burn up in short order. Dont do it.
Old Jun 3, 2006 | 01:20 PM
Kabomo's Avatar
I believe I bought a four channel amp for nothing. I guess the lucid rear speaker setup is an option I could go with...or maybe a sub. Not too fond of the S-pods. Thanks for your input NFR
Old Jun 3, 2006 | 02:01 PM
No problem, and FYI, the SPODS are the best way to get sound from the rear bar none.
tom9933's Avatar
I believe I toasted them with the aftermarket head unit so when I put my amp (75*4) in we replaced the tweeters with Memphis 1
Old Jun 3, 2006 | 08:42 PM
Kabomo's Avatar
Yeah, the Spods probably provide the best solution for sound, but I just like the hole in the loop. I also thought about buying the headrest speakers and switching out the tweeters, but I wasn't sure that you could do that with them. I really do like the look of those. But now, after looking at some 5.25" speakers...I think I just might go with the lucid rear speaker adaptation. It might be overkill...but I'm thinking it should only help the sound. Thanks you guys. Cheers!
Old Jun 3, 2006 | 11:53 PM
Kabomo's Avatar
I was just thinking about something. I got the polk/momo component set, and the crossovers allow for bi-amping (dual input) the tweeters and the woofers. Would it be a good idea to use the four channels for just those? Or run single input for the components and use the other two channels for a set of rear speakers? I know it'll provide more power per tweeter and woofer if you bi-amp them. but I don't think they need that much.
Old Jul 14, 2007 | 10:39 AM
matrix02's Avatar
I have an 07 and it came with the headrest speakers (2 on each hoop). I have the OEM headunit and wanted to know if I can run the lucid speakers and these headrest speakers together without cutting up harnesses (does it just plug n play)??
visionxboy
Dec 20, 2013 05:55 AM
Kiwi-S2000
Sep 8, 2007 11:50 AM
naseeb
Sep 27, 2005 06:12 AM
NorCalS2000
Jul 1, 2005 10:30 AM
njtripface
Nov 25, 2002 07:23 AM
