Oem music adapter
Old May 10, 2013 | 11:12 PM
Willy191's Avatar
Default Oem music adapter
Just bought an oem ipod music adapter 2.0 for my 2001 s2000 and I was almost done with installing it and found the back cable won't fit the stock radio anyone know a solution to did like is there an adapter I need to buy or any help will be greatly appreciated. Thanks so much
Old May 11, 2013 | 04:41 AM
ForNgoods's Avatar
Someone in the electronic forum might be able to help you out with this.
Old May 11, 2013 | 05:58 AM
takeshi's Avatar
This definitely should be in Electronics.
Are you following the instructions?
http://www.bernardiparts.com/Images/...k_AII33392.pdf
Old May 11, 2013 | 06:16 AM
Willy191's Avatar
So should I ask this in the electronic section or is it moved there already
Old May 11, 2013 | 09:15 AM
oth's Avatar
oth
The Ipod interface plugs into the CD changer port on the back of the headunit.
AP2 cars (2004+) use a different, incompatible CD changer, with a different
connector. My guess is you have an adapter made for a newer car. AFAIK no
one has made an adapter to make those ports compatible, so your options
probably are
a) get an adapter made for your older headunit
b) replace your OEM headunit with a newer OEM headunit
c) scrap the adapter altogether and buy an aftermarket headunit with the Ipod
functionality you want built in.
Old May 11, 2013 | 10:47 PM
Willy191's Avatar
08A28-0J1-810 Honda does anyone know if this is the adapter and oth your exactly right about the radio plug in the back in wont fit
Old May 12, 2013 | 05:21 AM
Willy191's Avatar
Bump
Old May 12, 2013 | 07:55 AM
oth's Avatar
oth
That looks like it is miscellaneous screws and brackets:
MusicLink installation instructions
I do not believe there is any easy way to adapt the Music Link to the incompatible headunit - the headunit
manufacturer changed, and I suspect that an adapter would need to do more than just match the wires.
Old May 13, 2013 | 10:35 AM
hand banana's Avatar
im not 100% but im pretty sure that adapter only works with newer oem radios.....
i have one in my 2008 and i love it, i didnt plug it into the back of the radio tho, behind the trunk carpet by the spare tire there is a harness for the oem cd changer, you need to buy the Y adapter harness 08A31-0F1-000, plug that harness into your factory cd harness which will allow you to plug in the music link, here is a link to the Y harness
http://www.ebay.com/itm/2005-2008-Ac...06729c&vxp=mtr
Old May 14, 2013 | 07:34 AM
takeshi's Avatar
^ Mentioned in the instructions I linked above.
amielo
Jacksonville
Mar 18, 2011 11:28 AM
senninha1994
Feb 21, 2011 08:49 AM
oldsportbiker
Jul 20, 2008 03:28 AM
hamsterguy67
Dec 11, 2006 11:21 PM
s4play
Feb 22, 2006 07:06 AM
