Opinions/Info needed
Old Dec 13, 2004 | 02:07 PM
GSteg's Avatar
get a small amp if u don't want a new headunit. even a new headunit will not mean much if you want your music to be noticeable louder. the most a headunit now will crank out is 27w per channel from alpine. They is only ~7w more than the average headunit (most are 20w per channel). 7w won't make a difference.
a small amp will cost less than a new headunit and will provide much more power at least to the point where you can tell.
Old Dec 13, 2004 | 03:07 PM
MULDER's Avatar
Can you give me some ideas of what type/size amp we are talking about?
Old Dec 13, 2004 | 03:27 PM
NFRs2000NYC's Avatar
you need a hu first. The stock HU puts out 10w per channel of muddy sound. A new one will be 25w per channel, and the volume is much cleaner.
You should be more satisfied with it, if not, then, and only then get an amp.
Old Dec 13, 2004 | 05:09 PM
ATF Kuk's Avatar
Banned
i agree.
very well said GSteg. although i do like more dynamic range. i would suggest a bigger amp. something like 100-150 watts rms.
this would be a good choice if u do not wish to change to an aftermarket radio.
the s2k puts out a lot of road noise. in order to overcome the road noise, u would have to turn up the volume to a higher decibel level than the road noise. with a small amp, i feel the stereo decibel level can not exceed the road noise decibel by much without distortion.
with a more powerful amp, it allows u to reach a higher decibel before distortion comes in.
Old Dec 13, 2004 | 05:24 PM
MULDER's Avatar
Are there any aftermarket HUs that are compatable with our extra controls on the left side of the dash?
Also, what is a 'prefered' amp for this application.
Old Dec 13, 2004 | 10:13 PM
ATF Kuk's Avatar
Banned
all u need is a DCI to make some of the head units work with the factory buttons. as far which brands or models, i am unsure of. maybe another member can answer that for u.
as for the amp, how much would u like to spend on an amplifier? price will help greatly.
Old Dec 14, 2004 | 12:43 AM
Ludedude's Avatar
Administrator
This solution works for most aftermarket headunits to interface with the dash controls.
http://www.gofastlab.com/s2ki/product.php?...85&cat=0&page=1
Old Dec 14, 2004 | 03:29 AM
MULDER's Avatar
I agree, thats what I want to know...how much is this gonna run me. It also seems people are split between getting a HU and an amp .
Old Dec 14, 2004 | 09:11 AM
Garbage in, garbage out. An amp will just amplify the crappy signal the HU provides.
Old Dec 14, 2004 | 10:33 AM
Ludedude's Avatar
Administrator
