PAC SWI-3 Alert
Old May 20, 2001 | 06:33 AM
NSXS's Avatar
I installed the PAC SWI-3 in my 2000 S2k (#7565) using the specified 2.7k resistor between the SWC input and ground. I couldn't program the PAC once I installed it. The symptom was that the first LED would turn on then immediately off when I pushed the program button. The SWI-3 would then be frozen. I fixed the problem using a 4.7k resistor instead of the 2.7k. The 3.3k specified for model year 2001 may have worked, but I didn't have one sitting around. So try replacing the 2.7k resistor with a 3.3k or 4.7k if you have the same problem after installing a PAC into a 2000 S2k.
Old May 21, 2001 | 06:20 AM
MacGyver's Avatar
See my website for that problem and others (and their solutions...).
Old May 24, 2001 | 10:07 PM
lucid's Avatar
Great post, I'm doing the install right now and using the 2.7 on my MY2000. The I pressed the program - light goes on for 1 sec then off - frozen. I was just going to try a 3.3. I'll let you know how it goes. "orange orange red gold" right = 3.3k? I gotta brush up on my stuff.
Old May 25, 2001 | 01:06 AM
lucid's Avatar
Yep it was the 2.7k res. that was the problem. I replaced it with a 3.3k and it works great. I didn't bother to hook up the mute.
I ended up soldering in the car which I really tried to avoid but i was careful. I had a cookie tray on my lap!
One of the ways I got the signal remote wire was removing a green rear speaker wire from the Honda harness thats not used anyway. So you only have to have 1 honda harness.
Old May 25, 2001 | 04:17 AM
Barry in Wyoming's Avatar
[QUOTE]Originally posted by lucid
[B]One of the ways I got the signal remote wire was removing a green rear speaker wire from the Honda harness thats not used anyway.
Old May 25, 2001 | 07:05 AM
Yellow S2000's Avatar
Barry I think what he is talking about is that the Mute button is in the wire harness on the car.. The after market wiring harness does not have a wire for the mute button and but has a slot in the harness for it.. What I did & look like lucid is backed out one of the wires in the after market harnes that was not being used like one for the rear speakers & put it in the slot for the mute button.. Very easy & nice looking install... Hope this helps...
Old May 25, 2001 | 08:50 AM
Originally posted by Yellow S2000
The after market wiring harness does not have a wire for the mute button and but has a slot in the harness for it.. What I did is backed out one of the wires in the after market harness that was not being used like one for the rear speakers & put it in the slot for the mute button.
GREAT...perfect explanation and that will save me time. I have bought male and female adapters (70-1721 and 71-1721) to "break out" the speaker output wires and the antenna motor wire to supply signal to the amp and to turn on the amp. Also I will "break back in" the amp output to speaker connection.
I'll have to look at the harness and move one lead like you did to keep the mute control going through the patch to the radio.
I hadn't thought of that before this post. Thanks.
Barry
Old May 25, 2001 | 11:36 AM
lucid's Avatar
The standard honda harness had I think 5 unused leads 4 for the rear speakers and a dimmer. I pulled all 5 out but put one back in *green* in pin 3 for the green PAC signal wire. It slides really easily - piece of cake. just remember the resistor - orange/orange/red/gold.
watchdogd
Aug 7, 2011 07:41 AM
spyhunter
Oct 25, 2006 02:08 PM
GoCatGo
Sep 26, 2006 03:55 AM
124Spider
Oct 19, 2005 05:17 PM
S2K-REPENTIGNY
Jul 2, 2002 05:52 AM
